2005 Chevy kodiak 4500 Shutting Down
Jan 8, 2024
5
Columbia SC
I have a issue with the engine shutting down. I lose FRP Regulator Fuel Flow Command when this valve goes to 0 the truck shuts down then the valve comes right back. The truck will restart after it sits for a while then the same thing happens again. Where does the ecm get the load value from?
Can anyone please guide me to what would cause this issue.
Vin # 1GBE4E3245F512132
1,755
0 is actually full open. Which is what it would try and do to keep the pressure up if it suddenly dropped off quickly. I'd check for a restriction in the fuel supply. When's the last time the filter was changed?
1,755
Water separator and filter are one and the same for the stock Duramax.
