LB7: 2001 FICM bad?
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,109
Phoenix
Is there anyway to test if the FICM is bad? Did an injector install and #7 injector is still showing bad. Could a bad FICM be the cause?
What would a new one cost?
paint94979
Beer Nazi
Sep 18, 2006
11,714
history of the engine? estimated hp? how high is the balance rate?
5,031
have you done return rate tests on the suspected injectors?
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Think if you might have tightened one of the #7 injector wire nuts to tight and the wire swung around far enough to touch the valve cover? Get a schematic for the 01 FICM and see if #7 wire connections are shorted to ground, should unplug ECM connections also.
D-MAX Mafia
Nov 4, 2009
1,109
Phoenix
Connections were good and not touching anything. Just pulled the injector to get swapped out tomorrow for another one. If that still doesnt work I'll know its something else.
