LB7: 2001 5 speed allison tcm ground issue. in need of ground wire diagram of body harness
bonomax
223
Hermitage, PA
Hey guys have grounding issue with tcm. Check all the ground on the motor and frame everything seems to be grounded. I'm in need of wire diagram for 2001 dmax with allison 1000 5 speed. Really just wanting to know where the ground wires go to for the tcm. I already have a pin out diagram of tcm. Just need body harness diagram. Or if anyone knows where the tcm grounds to if their is fuse or ???
Thanks in advance, tom
bonomax
223
Hermitage, PA
found wiring diagram. those 2 ground wires pin 1 and pin 5 tee into one location at S103 then to G105. anyone know where those S103 and G105 locations are physically on the truck?
in the attached is diagram for 2001 TCM wiring
Starfire47
Jan 20, 2021
Long shot, but do you still have the wiring diagram for ground locations? I cant seem to find them attached.
Thanks!
5,052
Thanks!
Engine block ground are at the front of the block, just above the upper oil pan on the left and right side. follow the main grounds of the batteries and you will find them. there are 3 on the left side and 2 on the right IIRC
