20% over injectors
davig
195
west jordan, utah
I need to get new injectors and was thinking about getting 20%-30% reason being I don't think I want to build the engine. What are your guys thoughts and experience with these sizes. Would I have to get my truck returned for the bigger size? What are the pros and cons of doing this? I was planning on getting an airdog also when I do this, What airdog would you guys recommend?
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
Bigger nozzles = less PW! That's a good thing:thumb: Yes it would need to be retuned. And any AD with both WS and filter are great. Delete your stock filter while your at it.
56taskforce
1,074
51
Get new Bosch stokers now tuning, build the transmission get lift pump, then air then injectors.
davig
195
west jordan, utah
Is 30% injectors the highest you would do on a stock motor I am planning on doing the trans I just didn't want to get into the motor anytime in the near future.
Bonestock
1,358
Worland Wy
I have had 15% 30% 45% 70% 80% and 100% injectors. IMOP if you are going to run stock fuel as in cp3 go with stock injectors. IF you are going to add a 10mm pump or dual c's add some injector.
S Phinney
4,011
Quncy, Fl
I run 50 over on my 438k stock motor. I'm using the 8 hole motorsport nozzles. They are stock but flow 50 percent more than the oem. I have used 30 overs on it before. I like the 50s that I have now better. Mostly because of some benefits of the nozzle design.
