LB7: 1200HP build
02ilduramax
632
3
fulton,illinois
looking for suggestions of what all is recommended in a 1200hp build as far as internals go I have carrillo rods already and the block is .020 over truck will be drag race only possibly nitrous occasionally
slowlml
Undercover Epa agent
Feb 6, 2015
577
53
Strasburg Va/Wardensville Wv
Do some searching on here for what similar builds have done. Im sure some guys will chime in though. I would definitely go with fingers cast pistons, 425s or 625s on the head depending on your air setup, key cam and crank, girdle of your choice. If youre doing a cam can go af but in my opinion i dont think it helps much. People still snap them. The big money cranks havent been the fix alot hoped for either so whatever your pockets feel like doing there. Fill in the blanks with arp hardware for main studs etc.
4,953
LBZ block or newer
SoCal marrow rod journal crank
fingers cast pistons or your choice of forged pistons
H or HX bearings
Large cam to match the large single and heads you plan to run.
Heads I would not run stock w/ ported, since i can only assume it’s the lb7, I would start with edlebrock heads and port those. Stock when ported tend to crack easily
O-ring the block and run your choice of head studs
Key the typical crap
Run a higher volume oil pump
Girdle and billet caps are your choice.
Don’t run a billet flex plate, use a BD if you want to upgrade
KyleC4
470
Bay Area
LBZ block or newer
H or HX bearings
Why not a billet flex plate? Seems like the one Guy has would be a good choice especially since it saves some weight on the rotating assembly.
4,953
It’s not helping rear main bearings or thrust bearings with a converter attached. Mahle/clevite need to come out with better bearings... only so much can be done.
This is not falling in line with the Callie’s thrust bearing issue, it’s something else that has slowly been coming up more.
815
Thanks! :thumb:
KyleC4
470
Bay Area
So how much axial thrust does the Allison/drivetrain create? I know manual trans assemblies create a lot of axial thrust that beat on thrust bearings. So I’m thinking then that the stock or BD flex plate does just as name implies, flexes and dampens the thrust load that would be put on the rotating assembly to help the bearings? Mainly thrust? More of an issue for vehicle that are doing only drag and boosted launches? Sorry OP for taking up some of your thread with my questions
S Phinney
4,011
Quncy, Fl
Post some pictures of what you are seeing please. I personally haven’t seen a issue so far with the billet flexplate and having a bearing issue.
4,953
I have none to post that are my own. The other shops may do so if they would like (not my place). I’ve only used stock or BD flex plates in the builds I’ve done with no issues.
Bdsankey
3,910
1,074
Neenah, Wisconsin
LBZ block or newer
H or HX bearings
^ This. A single is much easier on the bottom end than a set of compounds or triples simply because they tend to not build as much power down low.
Unless brad sold his turbo already id go pick his up. He did 1300+ on it as a single at high elevation
It did 1340/2200 corrected at 7800DA in the dyno cell on 1800us with Exergy modded 250s with a 0.041" and 0.088" jets (one each). The next day it went 126.85mph @ 7620lb @ 8800DA which put it at 1055hp to the tire on a single 0.062" jet. That was on a Forced Inductions V4 ETR 480/96/1.10 T6 with a Borg V2 race cover.
If someone's goal is to build a race only truck that won't be street driven its a fun setup. I knew it was going to be lazy on the street, I just didn't realize it would have been as lazy as it was.
D_Ferrante801
I hate everyone.
Apr 2, 2019
66
T6 on a duramax is not fun period. Unless you like to daily drive with a spool jet 24/7 and even then is not enjoyable. I even did some secret squirrel shit in your file to ATTEMPT to help spool up LOL.
Bdsankey
3,910
1,074
Neenah, Wisconsin
Honestly what ever you did worked well at sea level. At elevation it wasn't happy. With that said, I would argue on a dedicated drag/puller it would be much more ideal than a street truck as big single chargers are easier to work on and easier on hard parts.
