The Dodge axle shaft is 22mm longer than the GM, but is the flange bolt pattern the same?
Micheal Tomac been pulling forever Aug 12, 2008 273 0 16 MI Aug 29, 2016 #1 The Dodge axle shaft is 22mm longer than the GM, but is the flange bolt pattern the same?
ikeG Oughta Know Better Apr 19, 2011 2,429 128 63 Western PA www.facebook.com Aug 29, 2016 #2 Micheal Tomac said: The Dodge axle shaft is 22mm longer than the GM, but is the flange bolt pattern the same? Click to expand... That's a good question. Not sure on the pattern but GM takes larger bolts. Would at least have to drill out dodge ones if they are the same pattern
