1.15 ar for towing
gmduramax
Shits broke
Jun 12, 2008
4,048
231
Nor cal
I’m not sure if a ported IHI is just that much better but I towed 10k lbs up a decent grade and I removed the regulator and just ran a line like factory to reduce boost. I am at sea level and egt never went over 1200 on a 100° day. I want to say total boost was 30psi and the big turbo was making 20psi of it. And I was using every bit of 500hp or so to maintain 80mph
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
thats insane. Under full throttle on my max effort tune making 600 plus whp I think its around 50-52 psi of boost and my s475 is only around 20 of it.
5,056
trying to remember.... I think it was around 8 psi when total was around 30?
That puts the small turbo at 22psi like I was wanting you to shoot for. Under that, you are in a worse efficiency range of the small turbo and egt’s go up.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
so its a good thing? I thought in order to calculate the valley charger psi you had to do a pressure ratio calculation to figure its boost without the help of the larger charger?
5,056
Yeah you should be letting the gate open and make the 475 drive more there.
This is where I was saying playing with the regulator to get it to open the gate so the stock turbo stays in its efficiency range and the rest of the pressure is made from the big turbo
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
ok! im following now. so with the gate closed off for towing im staying in the efficiency range since total boost and fuel is so low. If i leave the gate closed off for full throttle, I will put it out of its range when i increase the fuel a whole bunch and over speed the small charger since it cannot bypass the extra drive pressure.
5,056
Na, that’s how you figure out efficiency ranges on turbo maps between turbos. You find the pressure ratios and plot them along with either VE or hp.
5,056
Yup, so try cracking the regulator a 1/4 turn to 1/8 turn at a time so you keep the small turbo at the right boost and the waste gate starts to open to let the big turbo come in
5,056
In the 02? Surprised it wasn’t laggy. It didn’t like no regulator when I had it
