08 H2/LMM harness help needed
Dp81
May 10, 2022
3
So I have an 08 Hummer H2 and I'm trying to do an lmm swap. I ran across a wiring conversation that led me here. If anyone out there knows anything about rewiring the harness please 🙏 HELP !!!!!!!
1,611
Moved to the swap section and retitled the thread so others will see it. Good luck to you.
1,756
go to GMupfitter.com. they have all the wiring diagrams in PDF format. download the one(s) you need and study it well. it should have all you need
kidturbo
Piston Tester
Jul 21, 2010
2,333
1,103
Somewhere On The Ohio
www.marinemods.us
Here ya go. This should help..
I typically tie all the pink wires together, along with the blue wire listed as Wakeup Serial Data. The single red wire goes to battery. That will get ya up and running. However the MAF pink should be kept separate as shown below, so a bad MAF doesn't leave ya stranded.
Washx3
Feb 22, 2021
3
Did you get this completed?
Washx3
Feb 22, 2021
3
Where is this thread that you moved to the swap section? I am doing the same work and having issues with the communication
