04.5 LLY swap into 02 LB7
ryancalcote35
Jan 24, 2024
louisiana
The LLY harness that goes to the fuse block under the hood has a pig tail with a plug that goes to the cab harness of my lb7. Question is what pin outs do i need to be able to splice them together. Lb7 cab harness has a 3 wire to the plug and the lly harness from engine harness has a 6 wire.'2 different style plugs'. Any help would be appreciated. Thanks
Bdsankey
3,914
1,074
Neenah, Wisconsin
For awhile BT Diesel Works would modify a harness for this. I do not know what work he did to perform this.
If you had an 03-04 LB7 it would be plug-and-play with the LB7 chassis harness but that is not the case here since it's an 01-02 truck.
ryancalcote35
Jan 24, 2024
louisiana
yeah i read up on that. im not sure if ill need the harness beings if i can figure out the 3 wire chassis harness pin out to the lly harness that has 6 wire. If i can figure out the pin outs between the 2 then i can splice the lly 6 wire plug onto the lb7 3 wire and hook them together
1,611
Theres a boatload of early LB7 to LLY swap threads, that one is the only one that even slightly outlines which parts work and who currently to contact about conversion harnesses.
Bdsankey
3,914
1,074
Neenah, Wisconsin
Reactions: 2004LB7
