LB7: ‘03 No Start Without A Little Help
9,903
149
Have a chance to buy an unmolested ‘03 ECSB for cheap. 260,000km on it. No idea if injectors have ever been done. Has a brand new cp3. Runs fine with supposedly no haze or anything but it’s hard to start. But just a tiny puff of wd40 and buddy says it fires right up. He’s thinking injectors but I’m not so sure as the no haze at idle thing.
What are the chances it’s not injectors? I’ll have to do all the tests to rule them out obviously if I buy it. Just looking for opinions from the LB7 crowd.
Dukchunter
57
I wouldn't touch it without a compression test... needing wd throws a red flag up to me for low compression. Just my 2 cents
I would also be checking for blowby out of the oil filler neck.
9,903
149
It fires right up after you shut it off and wait a couple minutes. It’s only after it sits for longer than 30min or so that it has issues. And like I said, no haze.
1,751
Being that it starts up after being off for a few minutes I would say it is a miner fuel line leak, maybe at the filter head.
If it was always hard I would guess high return on injectors.
If I needed a truck, what you discribed wouldn't scare me and I would get it
Dukchunter
57
Once warm things expand and can cause higher compression therfore a starting easier while warm... can also check to make sure the fuel system is staying primed... could be losing prime over time also. Starting with wd may get it running to get the fuel system reprimed... alot of variables here. I would get compression number though before anything
9,903
149
Kinda what I was thinking and hoping. It is a 15y/o unmolested truck so it could be anything from the pickup pos hose in the tank to a bad o-ring somewhere inline to a leaking filter head. Gonna give buddy a deposit on it tonight and then go give it a once over next week when I’m off work and potentially buy it.
Again it’s the no haze thing that has me believing it’s not injectors or bent rods. I guess I will find out.
Dukchunter
57
Prime it up using the primer on top of the filter housing. If it's a priming issue the prime should get hard and truck should start fairly easy
9,903
149
Well I’m picking it up Monday and trailering it home. Hopefully I got it figured by the end of the week. I’m hoping it’s something simple and dumb. Supposedly the guy that owned it before that did the cp3 may have done a bunch of tests including running clear fuel hose looking for air and bypassing the fuel filter but I dunno what kind of quality or workmanship went into these tests so I’m going to start off with the basics. Hell it may even have two o rings on the fuel filter base or something dumb like that for all I know.
9,903
149
So got the truck home. As mentioned it runs pretty good no haze but shut it off and immediately try to restart it and nothing. Tried to log it and balance rates wouldn’t work and then nothing would work. Tried to read the tune and that wouldn’t work so tomorrow when I get home from work I’m going to dig into it some more.
Turns out it’s not exactly unmolested as I did notice the factory filter has been deleted and it has an air dog so I’m going to see if I can find a stock filter head as I want the pump for my lml.
9,903
149
Finally got it to bbx log.
At idle cold
Actual vs desired rp are both at 42mpa
Bal rates were all between -1 and +2 except for two cylinders that were -3.6 and plus 3.9.
After running for a couple minutes all the bal rates went to 0mm3.
Shut it off and it had a a 3 second crank and rp went up to 7.6 and it started.
In park bal rates 1-8
-1.5
2.8
-2.9
2.7
2.0
-2.3
-2.6
2.9
9,903
149
After letting it warm up a bit sit for a couple min then crank it won’t get above 6.8mpa actual frp. RP is too low. Time to do some return rate testing.
Still can’t read the ecm or get my 7.5 scantool to work though.
1,751
I wonder if the lift pump was a bandaid for return rates getting a little high. Then when they exceeded that it wouldn't start until the rpms where high enough, thus the use of WD40
What are your cranking rpms? Does it help if you unplug the pressure regulator?
9,903
149
How much fuel pressure are you getting from your Air Dog to your cp3 ?
Not sure. Need to put a gauge in it yet. It has clear fuel hose on the line between the ficm and the cp3 with no air in it if that means anything. You can hear the pump build pressure though.
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
There is a shop local to me that is famous for this. Seems like he has his customers jump for the lift pump band aid pretty quick when they hear the price difference of that vs. injector replacement.
