GMC 5500, Duramax engine.
One day the engine just stopped and never get started again. Tried to diagnose the problem using BOSCH KTS, which hardly works and if only using Global OBD. It hangs over all the time and always shows mistake Р0090 – Rail pressure regulator. Upon start rail pressure immediately goes from 0 to 180 MPa, but car doesn't make any attempts to turn on the engine. We have checked the resistance of Rail pressure regulator as well as wires on it - no problem there.
There is an assumption that root cause is dead electronic control unit, BUT to make sure we have to check whether power is supplied to electronic control unit. Also, I know that there could be two electronic control units (ECM and PCM), and we don't know the status of connection between its. So, the need is:
- having these symptoms identify what could be a root cause OR
- share with me an engine management schema
ANY HELP IS HIGHLY APPRECIATED.
Cheers,
Vad
Cheers,
Vad
