Fuel injector knock
Trgglynn
56
Portland, OR
Hey,
My engine has what appears to be a fuel injector knock. Balance rate on #5 is +1.25. Cylinder 5 compression is 380 (tested hot). Engine is low on power and downshifting a lot when driving. Seems irrelevant to temperature and the power level seems to fluctuate.
Can someone educate me to why an injector would knock?
when I say knock I mean it’s like a “tack tack tack” noise, independent of the overall injector ticking.
1,756
Codes should tell you what injector it is
Also, post up all the injector balance rates and main rate. Both while in park and another in drive
If the engine is in limp mode it will reduce power and you will have a different shift pattern
Trgglynn
56
Portland, OR
Thank you for the reply. These were my most recent balance rates. I haven’t had any codes while driving, but I removed my fuel filter and drained the fuel, added 8oz of Diesel Power Service to the filter, reinstalled, primed with lift pump and bled air. When I started my RPM came up to about 450, hiccuped, went to normal idle, and popped P0193. Also, no limp mode. Just low power, excessive down shifting, and low fuel mileage.
1,756
Looks like you have a handful of leaking injectors. With the main rate that low there's a lot of extra fuel being injected and the ECM is trying to pull it back
Reactions: Bdsankey
Trgglynn
56
Portland, OR
So I replaced the injectors with new Bosch injectors about two years ago. Ever since then it seems like the fuel rate has been low. This is based on getting them scanned at a shop a few months after install. Would high return rates make the fuel rate low? How about the FPRV or the FPR?
1,756
Fuel rate doesn't really effect the main rate until you get into the extremes. Ie: so low the injectors have a hard time providing the needed fuel or so high it's hard to control.
High return rates typically manifest in low fuel pressure which can cause hard starts and low power under higher loads.
The two main things that will cause a low main rate is the injectors putting in more fuel then the ECM is asking for. Or a badly written tune that has fuel tables that don't match the needs of the engine. So unless you have a bad tune or a set of oversized injectors without a matching tune for them then it's probably leaking injectors.
Where did you get your injectors from two years ago?
Trgglynn
56
Portland, OR
Ah ok. So if I am understanding you right one possibility is that all the injectors are leaking/over fueling so the main rate is low? Something like not enough “restriction” from the injectors.
As far as I know the fuel pressure will reach 22-24kpsi. The truck starts up very easy.
I got my injectors from Lincoln Diesel. They’re Bosch new injectors installed 9/2021
I also replaced my CP3 in 11/2022.
Also, truck is on stock tuning. YZ5 tuning
4,969
You’re not the first one to have issues with Lincoln diesel injectors. Ever since they switched mfg, their stuff has gone down hill.
Basically the injectors are putting too much fuel in and the computer is pulling fuel back to keep idle rpm correct. Why it’s putting in too much fuel could be worn tips or pintle, bad sealing, nozzles are oversized/worn, poor rebuild and so on.
I’d suggest going with a set of s&s injectors or the like. Not cheap but also will not give you the issues you have.
Trgglynn
56
Portland, OR
Well that’s unfortunate. However, these are supposed to be OEM new injectors.. is the issue with Bosch or what? At this point I cannot buy a new set or be down with my truck. They are under warranty so I can pull and send them in one at a time.
4,969
The issue is with the lack luster rebuild shop most people use that at “Bosch certified”. I can go down the street and buy a set of reman Bosch injectors from a well known diesel supplier that services the US and they will pass on a bosch test stand but will cause smoke issues, knocking or won’t last. Send the same ones to exergy, s&s, flux or other good shops and they won’t pass.
See if they will warranty them. They have given everyone I know that has used their warranty, the run around at this point.
Reactions: Bdsankey
Trgglynn
56
Portland, OR
For sure, very similar story for the Ford 7.3L injectors as well.
Here’s my question though, my units were advertised as new, not reman. So what would make them knock so badly? Are Bosch injectors actually that fragile?
1,756
At this point I wouldn't trust that the injectors from LDS are 100% from Bosch and not touched by someone else or as James said, more then likely a Bosch "certified" shop that is rebuilding them. But with sub standard quality control so many will make it out that shouldn't
Are LDS injectors still only 12 months warranty?
Trgglynn
56
Portland, OR
Food for thought, when I got mine they came individually packaged in a Bosch package and sealed in Bosch branded plastic, with all the dust cover inserts of course. The new units have a 3 year warranty on them, which IIRC I warrantied one of them last year. Couldn’t tell you which hole it came out of but I bought another new injector, sent the old one back and they refunded me for the injector I purchased. Personally I haven’t had any issues with them but I can’t afford to go that route, at least as of right now.
What is weird is on my drive home just a few minutes ago, probably 10-15 miles, my truck seemed to snap out of “feeling heavy” and had good acceleration and my mileage went up to 19-21 cruising. It didn’t last long, but whatever is going on is intermittent and varies with severity.
4,969
Really doesn’t mean much. So do the injectors I talked about earlier.
Take advantage of the warranty. Most likely a solenoid going out
Reactions: kidturbo
kidturbo
Piston Tester
Jul 21, 2010
2,333
1,103
Somewhere On The Ohio
www.marinemods.us
A little dielectric grease on the connectors goes a long ways sometimes. I always say start with the electrical side, as a simple latch not snapped in all the ways has got me before. So simple to just disconnect each one and put a bit of grease on em, and reconnect. The slightest voltage related problem can have you chasing the wrong thing. Second, monitor the fuel pressure commanded vs actual and be sure it tracks pretty much spot on. While you have one injector balance slightly elevated, it doesn't always equate to an injector being the issue.
Trgglynn
56
Portland, OR
For sure. I don’t have any codes coming up. Any way to test the injector(s) before pulling them and mailing them? I’ve considered doing a “bottle test”, but need to research more about it. As far as I understand a bottle test wouldn’t necessarily pinpoint any one injector.
Trgglynn
56
Portland, OR
I’ll give the grease a go! I need to get a hold of a capable tuner. I ordered a Bullydog GT a couple years ago. I stopped using the times a good while ago but it’s what I use to monitor rail and boost. It seems consistent between now and before I was having issues.
3,914
1,074
Neenah, Wisconsin
Another one here for issues with LDS as well as "Bosch Certified" rebuild houses. I know of only a few companies I can call and guarantee I'm getting a genuine Bosch product. I've had multiple local customers (I'm local to LDS) have issues on initial startup or fail very very shortly after being installed. We won't touch anything LDS based.
I've had the same experience as James where a customer brought in Bosch sealed boxes/bags and the injectors were smoky/hazy piles of garbage. Sent them to a reputable injector house and they failed (this set went to Exergy when it occurred).
Any advice on how to narrow down which one is faulty? I don’t have any codes.
In my opinion no, with balance rates as low and a main rate that low as they are I would bet it's not just one injector having issues. Your best bet would be to call LDS and explain the condition you have, your concern, and the diagnostic work you've done thus far.
They likely will give you the runaround.
Reactions: 2004LB7
Trgglynn
56
Portland, OR
Well in that case, do you know of a reputable place to order fuel injectors?
