LMM stock tune needed
3,914
1,074
Neenah, Wisconsin
I have it in EFILive format but not HPTuners. HPTuners is nowhere near as common on the duramax side. If I had an LMM ECM I could flash it with EFI then read it with HPTuners but the only one I have here is DOA.
1,755
815
Do you know if you can flash an LLM calibration into an LBZ- E35 on a bench just to read it out?
Stroked06Goat
Syracuse, NY
Had to add '.pdf' as it wouldn't take the hpt file on the forum. Just delete off. This is 100% stock 2010 2500. Same op system
  • 2010 GMC Sierra 2500 Duramax 081220 stock JMM.hpt.pdf
Stroked06Goat
Syracuse, NY
Also for stock files, HPT repository has some. About 2 years ago they (unfortunately) wiped ALL the custom tunes from the library (lot of non epa compliant tunes were in there). I have a handful of custom from their repository if need.
Reactions: andrewb
Stroked06Goat
Syracuse, NY
Change your extension of course and watch your OS. Only have to worry about OS differences though in early 07. HPT repository was seriously gutted to appease the feds
  • 2010 GMC Sierra 2500 Duramax 081220 stock JMM.pdf
