ZF??
Dazedandconfused
Lost in the diesel smoke.
Jul 26, 2007
225
Nothern Ky
Quick question, is the BB version of the ZF the same as the one in the Dura? Just wanting to figure something out before I start searching.
Dazedandconfused
Jul 26, 2007
225
Nothern Ky
Thank you sir I thought so but wanted to ask the guys that knew for sure. Found a few BB ZFs a little cheaper then the others.
Andy
Dazedandconfused
Jul 26, 2007
225
Nothern Ky
Not sure if I can do it or not but can I run the ZF behind a 454 in my old truck? Would like to do that while I gather other parts to do a diesel conversion.
SmokeShow
6,818
Lawrenceburg, KY
They should bolt up. They have standard gm bolt pattern. Not sure on flywheel n pressure plate n clutch combo to make it all work. N then the hydraulics connected to zf.
duramax3388
447
Zanesville Ohio
i dont think the clutch would be as much as a problem as the flywheel i am not sure if one from a 8.1 will work on a older bbc or not if it does it would be pretty simple good luck and keep us posted on how it goes
