I think the standard gasket will go if you don't install a set of ARP head studs...
I'm still on stock gaskets and head bolts. 15k miles and probably 100 passes.
50,000 miles 600-700hp 200-300 hundred passes stock head bolts
I get it that you're making a statement of fact, but you're not saying cuz you've not had any problems in 15k mi and "100 passes" it's not a worthwhile or necessary upgrade/safeguard??? Are you?
And what's your max boost pressure?
I'm not saying it's a guarantee, but there's a reason why head studs are a highly recommended upgrade
FWIW
I had 20k miles of built trans max effort tuning abuse on mine before studs went in, no problems. I think the LB7's were more prone to issues tho
:dontknow:
I hate the stock setup, the double o ring is a PIA!!!!
I didn't say they aren't a worthwhile investment, just pointing out that the stock gaskets aren't guaranteed to go with added boost. And it isn't the studs that are necessary, it is the gaskets. The lb7 lly gasket is a bad design that will fail eventually, the head bolts are not the issue. It makes sense to do studs if you are replacing gaskets since you have the heads off anyway.
I hit 47-48psi in both my big tunes, and low 40s in my dd tune.
I really liked my y bridge from pro fab. It seemed to wake the truck up at about 2500rpm and up. I had the shorty with the boost tube that comes up over the alternator.
