Depends on the housing and turbine size. It allows you to run a larger turbine and/or housing and that will lower the drive pressure which will also increase hp and rpm range. Example,did a dyno session today with one of my 2.6 trucks with a DP 2013 PPL 2.6 turbo BMW S483-96 T4 and I was able to go from a 1.00a/r to the 1.25a/r housing and it increased power across the board with better spool up and lower pressures on both sides of the charger and it allowed it to pull hard all the way to 4750rpms. Hope tis helps and makes sense.:hug:
