I'm no turbo expert by any means, but I believe a lot of gain from the batmowheel other than the blade design and lightweight wheel, is the fact that it is a 6 blade design vs the 11 blade design of the factory wheel. The factory wheel is an 11 blade wheel which was designed to increase drive pressure so the egr valve works properly. While this billet wheel is lighter than the factory wheel, it's still an eleven blade wheel. The 6 blade batmo design effective lowers drive pressure as well as allows the larger fins to "grab" more air so to speak.
Again I'm no turbo expert but i've done a lot of research and I'm pretty sure this is correct.
