The way I was always told is if a filter gels up it will be full of waxy material even after the fuel has un-gelled.
Have you ever cut a filter open to verify it it is gelling or are you only assuming it is because it starts after you change filters?
Drain the fuel/water separator at every fill up on any filter that does it. Also it says to tripple the dose with howes the first 3 times. Also it says for diesels to run 1 oz for 2.5 gal of diesel. So 36 oz for 30 gal if I did my math correct. Also I let my truck run for 30 min or so to get everything good and cycled
Heck if you get the o rings I'll drive up and help you rebuild your filter head if Dustin is tied up
Did you ever pumping the the priming pump to see if it would start? I would hate to wait until next time, but it beats throwing parts at it.
Wait till next time
Pump it if thats a no go then replace the old filter and cut the old one open ASAP before it has a chance to thaw ETC.
