would like to hear some 1/4 times of lifted trucks
countryredneck
May 31, 2009
in the next 2 weeks i hope to me heading to the track once my new turbo is in and would like to know what to expect as a time.
anyone one have any 1/4 mile times to share on lifted/over sized tire trucks and with what go fast goodies done to them? thanks
countryredneck
May 31, 2009
seen a guy on another site with alomst the same mods, but on 35s with a 6" lift, he pulled off a 12.7, so i was hoping for low 13s... :confused:
Alligator
Nov 9, 2006
1,919
N. Idaho
I have a friend with a lifted Dmax (8" Fabtech on 37"x22's) with a 68mm Cheetah, FASS, EFI tuning, 4" exhaust ran 13.6 at RMR last year.
countryredneck
May 31, 2009
wow well i guess everyones setup/tuning is slightly different, but between this forum and 3 other the numbers are all over the place. i guess time will tell! :D
13,711
772
Bear in mind that you will probably not go out and run as fast as your truck is capable of your first time to the track. It takes a lot of time and effort to get your truck dialed in and running like it is capable of. Last year when I got twins I was running 12.6s and 12.7s at first. Over the course of a couple of months, with a lot of time and effort tuning and help and advice from some good friends, I finally got it down to the 12.0s and 12.1s. I think I could have gotten an 11 on the stock engine if it hadn't popped a piston.
Anyway, I'm just saying, don't get disappointed and frustrated if it doesn't run as fast as you think it should your first time out. Good luck and let us know how it goes.
countryredneck
May 31, 2009
ya im sure it'll take time to run its best. i hope to have a good time and be able to drive the old girl home, since its my work truck :D
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
wow i knew it made a differance, but not that much of one
Yep, it is the biggest internet debates over the years. Comparing vehicles run at different tracks across the country. In the winter some of the east coasts tracks will actually get a negative DA. The DA hurts naturally aspirated vechicles more then say turbo, supercharged, or ones with bottles though:D
So for the true test you can only compare what everone else is running the same day as you at the same track.
countryredneck
May 31, 2009
lol well im pretty lonely over here with a diesel, all ill 'compare' to is a bunch of 4 cyl imports :baby:
Utahski
Oct 20, 2008
546
Northern Utah
so ur sayin altitude can make over a second differance?
Altitude just sucks the power out of an engine. The figure given for a turbo engine is 2% per 1000' elevation. I'm at 7,000' and feel the difference just going down to 4,000. Driving at sea level my gas truck felt like it had a whole new engine. And at low elevation the DMax feels a lot stronger.
NitroDmax
Shake n' Bake
Nov 7, 2008
85
Some place up north
i asume brian found the problem or you just swaping turbos to fix it.
hope shes done soon so i can accualy go check it out.. would be nice to blow some black smoke at gimli
countryredneck
May 31, 2009
ya thats what ive read. ive never gone far enough up/down to actually notice it
