I did check the shift valve and that is where it should be..hey mike would a stuck valve in the pump/valve body deter the fluid? At wits end :0
Update: had the pump apart last night..everything was put together correctly..Installed new gaskets..like I said I have done about 10 Allison's and have never had an issue like this..the only thing I can say is different is the owner forgot to put Dex in the converter...I also got some Vaseline and lubed up the pump gears to provide a better suction on startup.. Maybe it will fix itself :/ ?
Cleaned the pump housing completely and made sure all valves worked well..put it back in the truck and it worked..thanks again guys for helping me out. Mike -YOU DA MAN
