The truck is a 2002 with the 5 speed allison. The kit included clutches, Transgo,overhaul, pump shim kit, lockup valve, etc. I have done about 10 transmissions before so I am 90 percent sure the assembly is right. When installed, the owner did not put Any fluid in the converter. He told me he dumped in almost 4 gallon and the Trans did not circulate or lessen the reading on the stick. I stopped by last night and there are no codes, but what I did notice was the PRND was blinking intermittently. When I went from R to D there was no change in the fluid level and no sound from the Trans engaging. There is communication to the valve body selonoids, checked that with efi live.
