Did you disconnect the main harness plugs on the drivers side of the motor? 2 bigger connectors that have the cam lock handles on them. If you did pull those apart to make sure you didnt accidentally roll a pin over somewhere. I have done this before and it caused me all kinds of fits. Good luck :thumb:
Great post. A month or so ago I had a bad fuel knock and two injector output circuit low codes. After speaking with a Colorado member here on DD's who is a GM tech, he advised me to disconnect the bale connectors and use needle nosed pliers to pull the male pins to re-seat them. Sure enough, 5 of them had become recessed and therefore not making good connection into the female side. Once pulled back into place (pins were now long enough to go into the female side far enough), truck ran perfect and codes have not come back! Don't know if this is just an LB7 bulletin but it couldn't hurt to try.
