Why you would NOT upgrade your turbo
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
I'm not raving about it. I have a modified LBZ inlet and modified intake track. It hasn't done JACK SH!T for my truck. I don't get better mileage and the power isn't up enough to be noticeable. It might be a bit faster at the track but I haven't raced it since the "upgrade". I'm not saying that it's not an improvement over the LLY inlet. You can clearly see by looking at it that it is. I just haven't seen any of the claimed numbers on my truck.
Oh, and I'm really skeptical on getting over 22 mpg (hand calculated totals, not highway estimates) in any LLY. I'd have to see it, smell it, touch it, hear it, drive it, and then see it again to ever believe it.
I noticed a big difference in the top end on my truck - not with his kit but with a stock LBZ inlet and an S&B LBZ intake. I ran .32 faster in the 1/4 on the same exact setup. The EGTs also went way down. I drive like an idiot too much of the time to get any kind of consistant MPG numbers. ChevyDieselLLY's truck gets over 25mpg highway (hand calculated) with just tuning and exhaust. I didn't believe it until both he and his wife told me that they drove over 500 miles then put in 20 gallons; and that they made a 950 mile trip from NC to MI and only stopped once to fill and still had fuel to spare when they got there, and then did the same on the way back. JonathanCasey also reported 23.5mpg hand calculated on a 12 second, 500hp tune on his stock LB7 turbo.
Now back to the interesting discussion of nitrous and tuning.
bonescarolfi
Sep 3, 2008
223
Marshfield WI
I don't have a whole lot of experience in any of this but it seems to me that either way you go (N20 or a bigger turbo) you better have some extra cash laying around because your going to need a built motor one way or the other. I know a few people from my area that tried to spray a ton of N20 and it didn't work out so hot for them. In my head i think a bigger turbo would be better. The power is always on tap, u don't have to worry about running the bottle empty. And larger turbos seem to be as lot more popular than huge nitrous setups so i would have to go the route that more people go and have less issues with. I nitrous was the magical answer everybody would have a few bottles in the box or trunk. I seen a lot more trucks and cars with bigger turbos. Not saying that nitrous won't make the power though, just seems a little more cumbersome.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Yeh, either way you are going to need a built motor. I don't care what anybody says, both are dangerous.:D
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
X2 zillion whatever.
After you get the motor/trans built, its a whole different ballgame and group of considerations.:D
ROGUE GTS
168
One thing I haven't seen mentioned (or maybe skipped over) is a big plus when you upgrade the charger.
What is the turbine backpressure vs boost on a stock charger? How about when you throw the coolwhip on it?
If you're seeing 2:1 pressure ratios at 40psi of boost, that's a crap load of force trying to stop the engine from turning. So that 700hp making it to the flywheel could be putting (making up numbers here) 750hp worth of stress on the engine.
This is in effect, coupled with higher efficiency compressor wheels/covers, why people can see huge hp gains at the same boost level.
There is a lot of power hidden on the backside of the turbo.
Diesel power
Jun 2, 2008
855
maryland
X 100000000:rofl:
Thats exactly right!
But most of the Group here wont listen anyway so it's most likely a waste of your time, like most of my post's........
But i agree 100%:cool2:
Killerbee
Got Honey?
a very good point. Keeping boost "reasonable" on a VVT, keeps passages open. There is no wastegate to compensate for serious backpressure. This goes a long way to support this thread, IMO. Just the concept that upping boost has far reaching consequences not understood by a lot of folks. There is no drive pressure guage in the truck. If there was, we would have a face to the concept.
Diesel power
Jun 2, 2008
855
maryland
on the upside you could build a DP guage for less than $30, i did
ROGUE GTS
168
I thought this was a pretty basic concept, there is no free lunch and as you get well outside the map of a charger the pressure ratio goes to crap and the aircharge gets very hot. Two things you really don't want.
As was stated, it's fairly cheap and easy to stick a pressure sensor just before the turbine.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
FREEBIE:D
attachment.php
Alot of memebers here use a real drive pressure gauge:hello:
I thought the point of this thread was to not upgrade the turbo and use N20 :confused:If thats the case how do you deal with the DP from a stock VGT?
ROGUE GTS
168
^ I kind of took the thread title as sarcasm. Like you really should upgrade the turbo before going to the sauce.
