Does oil or coolant flow through there. I'm guessing oil, but I'm not sure.
Item Number: 97262115
The engine oil cooler is not typically a component that goes bad, but should be replaced after any catastrophic engine failure. Any time metal is pumped through the engine from internal failure, it can accumulate in the oil cooler. Due to the stack plate design of the oil cooler, cleaning out that debris can be nearly impossible. The best way to protect a new engine investment is to put a new cooler on to prevent any contamination
has anyone used the ppe oil cooler blocker/relocater?
they do, if you look in their online catalog; its thereI think James (Maxlly) but his truck is pretty custom.
I dont think PPE still sells that piece?
