What are the chances the cam sensor and crank sensor have the same plugs? I'd go look but it's raining pretty hard right now.
Also make sure you have atleast 10 volts for cranking
Rail press needs 4000
It will crank before 4k , sure your not getting that mixed up with idle pressure ?
Built motor , duel fuelers , 60's overs , gtx4202r
It will crank with 10 psi it needs 4000 to start and run
http://www.duramaxdiesels.com/forum/showthread.php?t=14795&highlight=Start&page=2
They don't need fuel to crank but you need a min of 4000 to run most trucks idle at 6000 but it will idle at 4000 no problem .... You are right about injectors opening but if he has 1200 even 1500 it won't start and I would guess bad inj or cp3
Read post 67 there is a good document from GM in there and the whole thread is good for the OP
How to test the fca anyone?
You took it off at the cp3?I agree. It's in the future but not if I need a new cp3 or something. I've got no rail pressure. As a last resort I took off a high pressure line and got barely a drip while cranking it. I'm in denial with the injector thing. They're brand freakin new.
