Why are Cummins engines considered so "good."
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I had an Isuzu Pup back in the 80's and put it through pure hell. It was low on power but took everything I threw at it and then some. I could drive it all week on $8.00 worth of off road diesel and it never costed me a penny in repairs. I feel very comfortable knowing my Dmax was designed by Isuzu.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
our blocks are cast in the US. The RAW head, crank, and rod castings (they look like chunks of metal in the rough shape of a crank for example) are from Japan. The cracking of the caps, and crank/head machining are done in ohio.
so yes, our duramax's do have some overnight parts from japan. :D
[YOUTUBE]xKXZT70gwNg[/YOUTUBE]
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
Is the "Mad Scientist" character based on somebody we know?:joker:
13,750
821
I was looking over the new Diesel Power magazine (I think) a couple of weeks ago, and they had an article where the toured the DMax assembly plant. It showed a lot of the raw parts and assembly steps. It was interesting.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
x2 I completely agree. I mean WTF, Isuzu is one of the top diesel mfg's in the world. Those stupid hillbillies are so caught up in the "USA RULES EVERYONE ELSE DROOLS" thing that they dont realize if you go OUTSIDE the USA, Isuzu diesels are EVERYWHERE. They have been in the diesel engine business just about as long as cummins has.
X2.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
So my question is, what happens now that EFI will support the CR? Now that the Cummins guys can make the same and even more power while at the same time keeping there timing in check, will they be more reliable at 600-1000 hp range than they are now? Will they be more reliable than the D-Max
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Good question!
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
x2 on a good question but here's mine cause I know jack about CR Cummins. Even though their rotating assembly holds up will their pistons? What's the size diff from stock dmax injectors and Cummins?
Big Block 88
Nov 3, 2008
4,665
CR's are already are having issues with melting pistons as is, but IMO i think that timing from stacking is doing that... But then again there are piston melting d-max tunes out there weather it is due to timing or pulse or duration or whatever is causing melting issues.
cdub0451
Mar 8, 2010
19
Rio Rancho, NM
Somebody splain me the whole stacking thing. I know they have to disable the additional timing on one of the programmers. I'm a novice at all of the electronics side of diesel engines so break it down Barney style for us slow folks.
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
I don't know, but I'll bet the learning curve will be really expensive.:eek:
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
I love my dmaxs I have an 05 lly work truck that weights 13k plus daily has 138+k on it only had one set of injectors bad load of fuel did that an our 04 cummins dually(my dads) has only had that famous line for number 6 split an two factory lift pumps go out finally got him to let me put a Fass on it no other issues in a 140k knock on wood I love both trucks an would own either
'strokeThis_'07
Oct 2, 2009
107
Laramie, WY
I hope so. Really, it's a crap shoot. Save a couple guys that have scoped them, no-one really KNOWS what is going on. What's the timing? Don't know. Duration...don't know. Basically, we are at the mercy of the aftermarket, hoping that they know what they are doing. Our options are really pretty limited.
There's debate about the 3rd injection being the culprit to the 04.5-07 Cummins' more frequent melted piston problem. However, some have scoped it, and it only kicks in at certain periods.
I think it's actually kind of amazing we make the power we do with limited options, both Ford and GM can have custom tunes. I'm holding out hope that EFI is the answer, and yes, I plan to tune my own
Basically, you have three parameters altered in a CR; timing, pressure, and duration.
Many of these are changed by fooling the ECM. Tricking it into seeing less boost, therefore commanding more fuel. Or tricking it into seeing less pressure than it really is.
Example: Smarty replaces the stock ECM data with altered tables. The Quad Adrenaline takes the data from the sensor, alters it, and sends it to the ECM. The ECM will only command so much pressure, so the Smarty is limited. An external pressure box, like the Adrenaline or MP8, tells the ECM it's seeing less when it's really seeing what it wants, so it keeps commanding more to see the normal rate. Make sense? Actual pressure is 23k, the MP8 tells the ECM no, your only at 17k, so the ECM commands more to get to the 23k it wants, so your really at 26k
I'm by no means an expert, but that's a general example. However, programmers like the Smarty are so good, they take care of it all themselves, and the need to stack isn't as necessary, but some still throw a pressure box on.
Utahski
Oct 20, 2008
546
Northern Utah
You're right, it's stupid ignorance. The US market is a small part of the world market. Nevermind that the DMax is made here.......Isuzu's been making diesels as long as most anyone. They're used all over the world. From a google search......3yrs in the late 80's Isuzu was the world's leading med. and heavy truck manufacturer. It's one of the world's leading diesel engine manufucturers, they sure's hell know what they're doing.
