Whos running a MLG K?
The Kansan
Aug 30, 2013
179
Topeka, KS
Hey guys im getting ready to pull trans for some pump upgrades and mike L springs bc im building my engine. Im currently running a SC1057 which has been an awesome converter best one ive had but im gonna need something a lil looser for the turbo setup i will eventually be running. My truck has a Billet s366 on it and thats what it will have for a lil bit after the motor build but it will end up with either a big s400 single or s366/s483 compund setup. Is the MLG K pretty streetable and how does it couple compared to a 1057? 1057 couples better than any other coverter ive owned but its just too damn tight.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Mike can answer better then anyone, but I don't believe the K converter is designed for a larger then stock turbo. I'm pretty sure it's designed for a quick spooling vvt or small twin turbos.
But no matter what the K is designed for, you need to know what turbo your going to run before you select a converter.
A large S400 single will want something completely different then a small 366/483 twin setup will want....
The Kansan
Aug 30, 2013
179
Topeka, KS
I thought the k was around a 2500 stall and coupled well, but thats why im asking. So an s366/483 spools that much quicker than say a 1.0/87/472
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I ran the K. It's designed for higher stall s
Big singles. Spooled my remote s480 decently well with the setup I had. I'd run it again for sure but in your situation with a 66mm I don't think it's the best choice.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Ah, learn something new every day.
Mike L.
15,681
232
Fullerton CA
The G and the K are 2 different converters. The G is a tight converter and couples at a standstill. Let off the brake and it will walk away by itself. Great for blowing your tires off. The K is high stall and streetable. It stalls to a max of 2600 and couples like a mofo. The K was built for Verlon Southwick and Anthony Peleo . Both converters will push you up against the seat when you nail the throttle. Both are fun.
The Kansan
Aug 30, 2013
179
Topeka, KS
Thanks for the info. After my motor build i will still have just a single 66mm turbo for a lil while until i finish building my new setup, do you think the K is too loose for a 66 until i get a bigger single turbo or do big compounds. Basically can i grow into that unit so i dont have to do two different converters in 3 months? My 1057 wants to GO at idle. If its slick out the tires spin from just letting off the dam brake.
