Who do you guys recommend for EFI Live for the LBZ
kubitza123
Sep 19, 2016
144
Texas
Ok fella's getting ready to get the truck tuned . It's a 2004 CCLB 4x4 LB7. Only current thing that's not stock is the 4" stainless Banks exhaust . It's had a Banks 6 gun but I removed it since it was junk.
Wondering who has best tunes that make the most power and least smoke.
I'll be adding a down pipe, lift pump, and intake as well in the near future .
Efi Live and DSP5 switch so looking for 5 good tunes in let's say 50hp increments
The ones I've heard of are :
Kory Willis
Idaho Rob
Danville
Is there anyone else to consider and if so who? Also out of these three who do you guys personally recommend and why?
I'm sure they all do great work , just curious is anything in particular makes one of them the better choice ?
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Nobody wants to see a pissing match so it's fair to say all 3 are excellent tuners and you can't go wrong with any of them. Do a little bit of reading in the efi section you will be able to narrow it down yourself.
AJH
257
Memphis TN
Just to give another option there is Tony at ridge runner diesel performance. Take your pick all are better than banks. :thumb:
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I'll give a nod to Tony at ridgerunner since he's also a site vendor I believe, and I've yet to hear any complaints about his tuning. And is this an lbz or lb7? You have lbz in the title, and lb7 in your post. I only ask because a 5 speed trans will not hold as much power as a 6 speed in stock form, so stay realistic with your goals unless you want to add built trans to your list in the NEAR future.
5,933
Kory Willis
Idaho Rob
Danville
no such thing when you want the absolute most from the truck. it will be smokey till you upgrade turbo/s
3,733
305
Depending on how much you want out of the truck, it might be even more smokey once you do upgrade the turbo.
Small turbo = clean spool, smokey top end (or limited power)
Big turbo = dirty spool (and/or massive lag), clean top end
You want smoke free power, you need twins and/or a DPF.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Compounds Dave. Small primary with a larger secondary or two smaller secondaries= best of both worlds.
3,733
305
That's what I meant by twins :thumb:
But you are right, compounds is the correct term, and I should be accurate, especially when working with a newbie who might not know what I meant.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Lol sorry I missed the twins part... I have always called them twins but so many have trips now I have kinda switched to compounds. But I have gotten into a pissing match or two over me using the twins term instead of compound, that guy sure hated the term twins:rofl:
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
This is in no way a bash at him but isn't he the vvt guy... The op has an lb7
I have many lb7 with marks tuning, it's as good as his vvt truck tuning.
Mark, Tony, or Rob get my vote. Kory does well but he has to much going on in my opinion..
1,971
For an LBZ, Id lean toward Rob, for an LB7, Tony......but any of the 7 businesses in our vendor section that do tuning would be a good choice.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
From the sounds of your post, it sounds like you have upgrades planned for down the road. I would go with a tuner who is flexxible and reasoneable with retunes down the road. I do mot reccomend a built trans tune for a stock trans as the temptation is TOUGH to resist turning the knob up, there goes your box, and now you're forced to build your trans instead of doing it over time. So I would reccomend tuning for what you have, then upgrade as you add on stuff down the road. And I believe Tony at ridgerunner is about as reasoneable as any for doing this.
Jan 28, 2015
961
Ohio
I've had Kory and mark. Mark gets my vote hands down. Due to customer service. You can actually talk to mark on the phone. I got tires of emailing Kory.
roxyfever
Feb 11, 2016
191
terrell tx
I ran duramaxtuner on my old lb7 an really liked it. An I have ran rob (ATP) tunes on my old lbz. Both great tuners.
You won't be sorry with any of the recommended tuners mentioned. All are fantastic
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
Korys tuning and custom tuning went down hill big time. He is to big to care. Charges for tune updates.
I myself prefer Tony. He tuned both of my lbzs. Easy to get ahold of. Does not mind going over data logs. Also free lifetime updates. He was one of the orginal bata testers for efi.
