Whistle/squealing sound after headgaskets
MadMax17
66
maricopa, az
Make sure when you install the y-bridge that you tighten the lower bolts first as they will suck the bridge downward into the sealing surface. Then tighten the top and recheck all bolts, if this is not done then the bridge will not seal.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Finally got around to taking some stuff apart. My y bridge was loose but wasn't the issue. Somehow my passenger intake runner is leaking under the y bridge. Yay. Also my turbo is getting just a smidge of play. Not really wanting to tear it open just yet so I put it together and gonna wait till I can get a 63.5 cover and DP. Ugh. Issues issues issues.
Awenta
4,090
CT
A wheel and cover won't solve any kind of play
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
About what would a rebuild/balance run generally? Also just to clarify I've done more reading and the shaft has a very minimal bit of play up and down. None in and out. Is that normal?
