Can you post the pic's as attachments here? For us non-myspace users? Please
I will try. I was being lazy. Who doesn't use myspace
I cut a piece of steel out and welded the original hole shut. Then you can see from the one pic that I drilled another hole and welded in a 3/8" NPT bung and screwed a 3/8" hose barb fitting into that to run the hose to the turbo.
I second that John. I had a 4088 and the power to EGT ratio is wayyy off. Runs far too hot for the power you get, and it has the characteristics of a big charger as far as lighting but not the power. Pretty much a lose lose.
