WTF? I have been paying 80$ for amsoil in a 2.5 gallon jug. Tony im calling you today
You have not changed your oil since 09? When you ordered that crap lol.
You just need to make sure that you have enough clearance for the 20w-50. They make a 15w-40 also. I will be running the 20w-50 cenpeco in mine.
i can show you some 255k mile dmax bearings that look brand new... matter of fact, i have 2 other blocks with unknown mileage that have great looking bearings in them. imo, if you have the clearances right for what oil/load you will be running, the crank should never touch the bearings and cause wear/damage. if you will be making big power, you will need more clearance and a heavier oil.James theres a company out of Houston i believe they are called polymer Dynamics that does the main and rod bearing coating .I have a friend from Ok that is down there rite shooting a video of it for you tube and they are GIVING him 2 complete motor rebuild kit forged pistons and so on but they showed a cummins bearing that had 300k on it and it was trashed and they showed a coated bearing with 1 million miles on it that was like new.I had my pistons coated but didnt realize they did the bearing also or i would have had mine done.
http://www.youtube.com/user/TheDieselStop
I totally agree but if the coating is a good thing it doesnt hurt to go that extra mile either. IMOi can show you some 255k mile dmax bearings that look brand new... matter of fact, i have 2 other blocks with unknown mileage that have great looking bearings in them. imo, if you have the clearances right for what oil/load you will be running, the crank should never touch the bearings and cause wear/damage. if you will be making big power, you will need more clearance and a heavier oil.
Delvac is great oil. Probably one of the best oils on the market, and definitely the best in the mainstream market.
