Which leaves to pull?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Im going to pull some leaf springs to drop my ass end more and see how she does at the track. Any thoughts on which springs to pull??
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
if you really dont tow, just pull the over load, its good for close to an inch, leave the rest.
also throw some 3" drop shackles or build some.
i have drop shackles mike. dont you remember our conversation when i wanted you to lower your truck haha?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Hangers boss.... just ordered a set for mine.
You dont mind losing load capacity?
nope. i dont wanna do hangers cos i dont ever tow and if i do im buyin bags anyway so it should be fine. Even if you have drop shackles if you tow heavy itll still bottom out on the bump stops.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
So how did it work?
Worked well. I will get some pics up. Because the drop shackles crank the spring so high its a little nicer around town, doesnt feel so stiff in the ass end. One day when I finally buy some good shocks itll be really nice:rofl:. I just cant swallow that $270 price tag right now (yes im that cheap when it comes to things that dont make me go fast).
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Reno, so did you just do shackles or did you pull leaves too?
Ive had shackles on my truck for about 5 months now, and I pulled the overload springs and all the steel plates between the springs. I just ordered drop keys and will get hangers eventually as well. I can put pics up if you guys are interested.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Come install my hangars :hello:
haha theyre easy matt! why didnt you do it when you had the bed off for your airdog install? if you can do that you can do hangers no problem my friend. Just cut the old stuff out put the new in. Ill let you know when I buy mine, and them after that im gonna buy some bilsteins and ill be sitting real pretty. then 20s and ill be a happy boy
rushingbc
< I drive slow trucks
Sep 3, 2006
139
Beaufort, SC
so, did you take pictures??? :cool2:
I dont think i'll ever buy any other shocks besides bilsteins, best ride i've seen in my truck.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Ill get pictures tonight I didnt know if anybody wanted them. Ill take some of the truck and some of the stuff I pulled out and pictures of what youll have to do to make it work.
rushingbc
Sep 3, 2006
139
Beaufort, SC
saweet. I'm going to be doing some of that in the up coming days...
with the drop keys, what are you doing about the lower control arm bump stop?
Bentley
Doesn't know $hit...
Mar 7, 2008
193
Under a big a$$ rock...
I just hacked mine off and left about 1/2" of material so if it does come up to contact it won't be smacking frame. I tow a lot with my truck and it was getting annoying when it would sit on the bump stops.
Also, just as a heads up if I remember correctly when you get around the 5-6" or drop there isn't much you can do about axle to frame clearance. A friend of mine had a truck with 5" of drop in the rear and it would hit the frame all the time!
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
So going with shackles/hangers in the rear, it is obliviously gonna change the pinion angle.....Is it bad enough to were one would want to run a 2*-4* wedge between the spring and spring seat on the axle to bring the pinion back up a bit.......?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Im not doin hangers actually cos i just ordered new wheels :D. so its going to stay how it is. I think you saw it the other day its sittin pretty nice right now.
