Guys when you have to start bending and denting things are not right.
My experience with wherli custom fab that's normal.
the factory steel & rubber fuel return lines on the LLY run tight behind the stock Y bridge, they need to be bent back slightly to clear the 3" pipe. same with lbz and lmm
I would call BS if you claim to have installed a 3" y bridge without bending a fuel return line at all to clear the 3" pipe on '05-10. and I say that because I have installed all above mentioned brands personally myself and they are no different
Will this kit work on an LB7? It says LLY, LBZ, and LMM in the title but then states that it'll fit 2001-2010 models in the description.
