Yeah race N2O has sulfur dioxide in it to deter abuse. Unless the guy that fills your bottle uses medical grade N2O
I had 100+ 12 second fuel only passes and spraying it 4 passes did in my head gasket.
This doesn't sound so good for me lol I'm on pass 10-12
I wanna put mine under the bed like Pat suggested, I have the jets, just haven't gotten around to actually buying a kit, too lazy :spit:
You were running n20 on your stock motor?
Yes ran in on my stock motor. When I cracked a piston I wasn't using it though. I used it to see if it would help cool egts and its cheap boost in a bottle. Also to have it for now to make 1000hp on the dyno every now and then.
Perfect that's what I was lookin for, thank You!
You make 1000hp with a 68 on the truck?
Lol I wish!!! Guess I should have been a little more detailed. Motor is being built right now and ill be twinning it with either the 68 or my go with the 72 from mark. I could probably spray the 68 to 850-900 I would think.
I oversped mine Wednesday night at the track and it was only on a .054 jet. 125ish hp. I'm assuming that put me in the neighborhood of 725-750hp
That's the size I've been using is .54. I doubt ill be running the nitrous with the 68 alone though.
Isn't the 4094 good for 750 hp?
