where to buy lb7 injectors
stroke250
I May Be Lost...
Jul 1, 2008
490
Idaho
where is everybody buying lb7 injectors from?? also, have you had any premature issues with them after install?
thanks
stroke250
I May Be Lost...
Jul 1, 2008
490
Idaho
yep, its getting some smokey at idle. injectors were down at 60,000 for high return rates. truck has 120,000 on it now.
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
Isn't it still under warranty to get these fixed or are you thinking about getting some better injectors and fixing it yourself for good? You should get some nice 40 overs and turn up the horsepower while your at it. :angel:
Blueox03
Aug 12, 2006
668
Jackson County, MS
I would ask around here to help find a good dealer. Then take it in for the special coverage that covers the injects up to 7 years / 200,000 miles...finding a dealer with an actual mechanic is the hard part....
stroke250
I May Be Lost...
Jul 1, 2008
490
Idaho
from what i have heard there has been a revision to the special policy that doesn't cover the smoke at idle under the 7yr/200,000mile warranty. it only covers it for the 5yr/100,000 mile portion. i will check for sure, but i do have 45 over nozzles waiting to go in at this time, so i will probably have to do them myself anyways.
Subman
Old Geezer
Jun 27, 2008
3,233
10
80
Madras, OR, Pahrump NV
Here is an injector question on cores, what condition do the cores have to be in? I bought a set of injectors off a guy on ebay a couple years ago and really didn't look at them very close because I was sending them to get fitted with custom tips. Turns out the bodies are not much good either. So how good do the cores have to be to satisfy the core charge rebate?
stroke250
I May Be Lost...
Jul 1, 2008
490
Idaho
anybody else running remans from pensacola??? would like some more feedback before i put mine in.
SonicAudio
Jan 25, 2009
Texas
I have mine from there and have had no issues for over 8000 miles so far, as far as the core, I got a set of 8 on ebay and just sent them in to pensacola as i ordered mine, if you are concerned with them as i was being that i didnt want to have to replace them again call them, I was confident that they were the ones rebuilding them and would stand behind the warranty, the guy there really knew his stuff
stroke250
I May Be Lost...
Jul 1, 2008
490
Idaho
well the only thing with me is the fact that i am swapping out the stock nozzles with my new 45% over ones. good to hear you have had good luck with them.
Blueox03
Aug 12, 2006
668
Jackson County, MS
I know a couple people that got theirs there and they are satisfied. A good friend of mine has had a lot of 6.5 stuff from them over the years and highly recommends them. I wouldn't think twice about buying a set of injectors from p'cola diesel....
