Where did your piston crack?
Fingers
Village Idiot
1,717
96
White Oak, PA
I have a half baked theory I would like to check out.
If you cracked a piston, where did it crack? Left or right side? Or, looking from underneath the piston, the squirter cup side or the opposite side.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
37
Central Coast, Cali
www.sikdmax.com
From the hole, to the center.
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
I got one that looks just like sikdmax's picture.
I think they crack there because the piston uses the pin as a fulcrum.
Fingers
Village Idiot
1,717
96
White Oak, PA
All of them crack along the pin. It is the side or the piston that I am interested in. Left or right. Sik's is on the left, away from the oil cooling jet.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
Has anyone ever run a second squirter? Maybe off topic, but I think I see where fingers is going with this...
only potential issue I see with this is you might tax the stock oil pump a bit???
Might need a high volume oil pump to be able to use 2 squirters per cylinder effectively.
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
I'm no engineer but I'm thinking the same. Am I right in thinking the "dry" side is cracking because the heat isn't being dissipated like it is on the wet side? Basically the oil is absorbing and carrying away enough heat to keep the majority from cracking on that side. If that's completely off base or out of touch with reality let me know.
Fingers
Village Idiot
1,717
96
White Oak, PA
I am thinking more of how the wrist pin squirter "steals" oil from piston opposite the receiver cup. On my current pistons, I installed a divider in the cup to make sure the oil is distributed equally. Though I fear the opposite side will always be at a disadvantage.
