Question: What's the best additive to run in diesel
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
I have always ran Diesel Kleen grey bottle. It works too well for me to try anything else and be disappointed. Plus I get it at wholesale if I buy a case.
As long as you don't add 2-stroke oil, atf, or veg oil you should be fine.
BobbyBDirtyMax
US Marine Corps Retired
Feb 15, 2013
143
Madisonville, KY
I use Power Services Diesel Kleen and its a great product, also like Lucas Oils Fuel System Treatment, noticed in a few test running these 2 different additives the rails, lines, and injectors stayed clean per than just fuel alone and fuel Econ went up 1-2mpg:)
Operator1
477
NC
I have run 2 stroke oil, motor oil, hydraulic oil, a mixture of the 3, power service, schaeffer's, and currently using rev-x. As long as I put something in there, I feel like I'm helping.
madmax02
Apr 30, 2012
88
Taylor, Mi
I've used opti lube and liked it. I'm using the f-bomb and hellfire right now and really like them,
714banshee380
Dec 14, 2012
33
what's wrong with 2 cycle oil as long as it meets tcw-3 ratings?
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Nothing wrong with 2stoke at all!
Any good tc-w3 oil is fine i am using Klotz currently ive used amsoil,phillips 66 injecz.Also use the gray bottle in summer and the white bottle in the winter.Todays shitty low sulfer fuel doest have the luberplicity it should so 2 stoke as a supliment is a good move.
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
i raced 2-stroke dirt bikes my whole life and after seeing the nasty shit that comes out the exhaust i told myself i would never put that in my truck that has extremely small injector spray holes.
besides there are so many great additives specifically designed to combat the untra-low sulfur diesel, additives that have been tested by the companies that put them out.
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
its not the ash, i just cant see putting thick oil in a truck that is known for problematic injectors.
but if you can run it with no problems then good :thumb:
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Dp had a big thread on this a few years back, interesting results to say the least. It was supposed to be objective but who really knows? Optilube was hands down the winner, by a good margin. If I could get it in Alaska that is what I would run. The 2-stroke was not bad but not that good either, it is by no means was bad and beat out some of the other dedicated Fuel Additives...
baggedLB7
Goer
May 1, 2011
688
Utah
I run optilube summer blend it was high on the DP study I think number 4 out of 20 products tested and it is cheap to use.
Noreaster
2,910
Cape Cod,MA
just the top 10 from 2007 lubricity additive study
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
