LLY: Whats next for me?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Lift pump!! I have the same truck and it didn't run for crap over LVL-6 before the lift pump. I drilled the fuel fitting's and shimed it, also added a AIRDOG 150 L.P. with tank pick-up. That works well enough for the fuel demand of the 350 tune. Even with all of that it runs out of fuel on the 425 tune.
Then back to level 6 it is for now....
Duramax_JP
1,088
Id do a lift pump, my personal choice would be the airdog 150, then If i were you id take care of the little things too like tie rod sleeves if you dont already have them so you can launch in 4 wheel and stuff like a new downpipe and bd passenger manifold just so you know you have the best flow for your turbo but bthats just me. Id also think about adding like a cheetah if you dont wanna spend a whole lot on a turbo or go with MPI twins. Id also make the switch over to EFI Live and find someone to make you a good tune. Then maybe an injector upgrade of some sort, nothin crazy. Thats just what i think though.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I have EFI Live.
Looks like the general concensus is lift pump.
Is it really necessary for the lift pump to be one that includes a filter?
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
i have a Super Diesel lift pump that pumps through a Cat filter....i guess it depends on what type of lift pump you go with...most recommend running it with a filter but i already knew my pump (Carter single) could be reliable without being filtered prior, so I rigged the filter post-pump for the best flow capabilities and pressure monitering.
Duramax_JP
1,088
I have EFI Live.
Oops sorry wasnt payin attention. All that talk about the PPE made me think you had the PPE
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Lift pump ,fuel shim ,blocker plate, PVC rerought ,turbo ,lbz cp3
get your suspension set up as best as possible and possibly try 35s witha alluminum rim
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Try moving you shift points around and lower your fueling a little if you want more get up and go with the bigger tires
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Moving shift points where?
I have blocker plate and pcv re-route.
I bought the PPE race valve but couldnt get it installed because the stocker was impossible to get off.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Depends on your truck but i like the shorter shifts in the lower gears
4 and 5 I liked a little higer RPM you could probably run 4th gear in the 1/4
I know my friend has with 35s
I think you need to talk with Nick some more about TCM tuning:) Get that more dialed in for your truck
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
If it gives you any idea where my gearing is at right now, I'm at 82mph at 2000rpm. Overdrive, converter locked.
What is stock MPH at 2000rpm?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Anyone? Stock mph @ 2000rpm?
Nick sent me a hothothot tune today that im going to try, to go along with the Airdog 150.
How do i change the TCM?
My EFI live selection of folders doesnt include one that has anything to do with TCM, besides one that has to do with codes or something.
13,751
821
You have to download the TCM file from the TCM. I can't remember if you have to license to pull a tune or if you only have to license to flash, but all you need to go is click the Read PCM button at the top of the screen (the one with the green arrow) and select "LB7/LLY Allison TCM" from the controller section of the pop up window.
