What turbo for my 66
blue09dmaxx
Too broke for this shit
Jan 15, 2012
823
The south
I know I post a lot but I made my mind and bought a s300/400 twin kit will be using my t4 double bat 366 can't decide 80 or 83 and which wheel to put in
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
37
Des Moines, Iowa
How much cash are you wanting to spend? I would go with the bullseye S483 if cash didn't matter, or if your cheaper like me, just a standard S480 with a cast wheel and standard cover. I am not sure how much HP your trying for, but it is a lot cheap to make a plan and build the plan.
Bonestock
1,358
Worland Wy
66/80 will get you deeep in the 900+ range with dual c's and @ minimum 50% sticks. The Catamax is running this combo and has dyno'd multiple times 960+. He is standard cast wheels in both chargers.
skintback
Take this one to church
Mar 5, 2007
919
Florida
A s480 with ETT cast wheel race cover with stainless 1.3 v band inlet turbin housing is what i am going to run with my htt 66/71/16
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
The difference in spool up was noticeable for me change the wheel from cast to batmo in my 480, I would recommend it in with the 80 or 83 that you choose.
Talk to mark about the batmo in your 366 if you haven't done so already. You might not want to do that wheel in the s300
coker6303
Aug 6, 2009
2,484
40
Houston, TX
See can I run a 483 cast with my 66 being double bat
My understanding is your money is better spent with the batmo being in the atmosphere charger because it responds so well at lower shaft speeds where as you will be driving the hell out of that 366.
S Phinney
4,008
Quncy, Fl
Any wheel combo that move more air at low shaft speeds will be a big benefit. The atmosphere is where the HP is at. Getting it jump started is the key to it being efficient and a pleasure to drive.
pizza pig
I Like to Party
Feb 13, 2012
266
borg warner s488 with turbonetics cast compressor wheel, 1000+ hp capable and spools instantly in a 66 compound setup. And they sound unreal
