What sub setup are you using?
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
Sorry I'm just now getting to you. Had to mow the yard before the rain comes tomorrow. Let's see what we can do.
Having more amp power than the RMS rating on the subs gives you more flexibility. Once you start getting past the RMS rating on the amp, you start getting into distortion and distortion kills speakers.
Going to a 1 ohm load on the amp when the speakers are at 4 ohm gives you the most RMS power out of the amp (see below options).
Running a 1 ohm load on an amp designed to run stable at 1 ohm will not hurt it. The only thing you will notice is the amp will run a little hotter. However, this is where Steve was talking about turning the amp gain down and utilizing the head unit as much as possible.
You are right. Most companies under rate their equipment and RF is definitely one of those companies. If this is the actual power rating, this has the power you would need for these subs. So at this point you have two options:
Option 1) Get two 2 ohm dual voice coil subs. Wire each sub in parallel to get 1 ohm each. Then wire the subs together in series to get back up to a 2 ohm load. That would get you 628 watts (314 watts each speaker) @ 2 ohm.
Option 2) Get two 4 ohm dual voice coil subs. Wire each sub in parallel to get 2 ohm each. Then wire the subs together in parallel to get to a 1 ohm load. That would get you 927 watts (463.5 watts each speaker) @ 1 ohm.
Basically this amp will be more efficient at 2 ohms (82.3% @ 2-Ohm) than at 1 ohm (73.4% @ 1-Ohm) but 1 ohm will give you more power.
I realize this is a lot to take in but look at your options and make sure the box you get has an internal volume between 0.5 at 0.85 cubic feet.
Let me know if you have more questions and I will help as much as I can. You are also welcome to call me. If you want to call, I can PM you my number later.
(Having to go to bed now though. Have to take wife and her friend to the airport tomorrow morning at 5:00 a.m. :()
What he said.
And like he said I would run it at 2 Ohm not 1 Ohm
496 BB
Head Thread De-Railer
Feb 20, 2009
697
5
At your girlfriends house
Well I appreciate all the info here. Its all starting to come back a little bit now. I think I have decided (for now only) to buy the P2s in 4ohm and wire them to 4ohm into my amp that I currently have. I have talked to a few guys and they say its a pretty bad ass amp so hell it cant hurt to try it. Its rated at 320Wx1 bridged at 4ohm so it should handle it. Ive had this amp forever and its never hot or problematic. If it doesnt work then all I got to do it buy another one...lol. This way the wifey may not shit her pants when she shes how much it all is. That in itself is a very good thing :thumb:
What downfire boxes is everyone running? (Other than Josh) There was a place off ebay that has own website that claimed .77 ft3 each but Im not seeing how. Steve at Subthump said same thing as he can only get .55 I think.
PhilsLB7
Way Better Than Facebook
Jun 29, 2009
810
Tennessee
I looked at the box on Subthump and really like this one for a pre-fab box. As the description said, you don't have to cut any of the seat supports out, just drops right in without any modification. This is why I think they can only get .55 cu ft out of this box. You will be at the minimum air space for these subs but I think you will be fine. Let me know if you decide to get this box. I am curious to see how well it sounds. May consider getting one myself.
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
Laugh If U Want but my brother did this for me because i was looking for a little more bass just to "waken" the music up he has all the nice stuff of course but i got stuck with a crutchfield behindseat truck box for 1 10 and a rockford punch 75hd he put a lightning audio storm in the box and stuck it under the backseat facing up and tied it in to the factory stereo with a line out converter i will say for some cheapo system it thumps pretty loud makes me happy :coolspot:
9,905
151
I'm happy with my Hertz audio stuff I have in my truck.
