What stall
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
If I was to get a 3000 stall converter, is there any negative effects? I had asked for a high stall one but must have been sent the wrong one. I'm trying to spool a very large single turbo. This will be my last try before switching to a handshaker where it's easy lol
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I don't know if this helps but my stall is about 3000 and I can spool my S475 with ease. Switched from a SC 1057 to this high stall precision and its night and day.
onebaddmaxxx
1,212
Cecil County Md
George did the trans in the pulling truck and it has stock gears, do 3rd gear starts and spool a 475 with a 96 wheel and 1.1 wheel pretty effortlessly with a Suncoast 1055. Takes about 5 seconds to spool it and it's pretty much screaming full boost within a few feet. Truck has 100% injectors and twin pumps also
onebaddmaxxx
1,212
Cecil County Md
Here is info from sun coast:
Suncoast's most popular converter, which incorporates an OEM style stator and custom modified impeller to allow low end torque multiplication (gets the load moving) and high end efficiency (puts the power to the road). Combined with the Sun Coast triple clutch and billet cover it is a great converter for daily driving, towing and or racing. 2400 stall
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Don't know if it matters but I think my ar is .90
83mm turbine with a .90 housing is nothing to spool. I spool my s472/83/.90 with a stock stall ml converter absolutely no problem. Spooling a 96 mm turbine with a 1.25 housing is a whole new ball game. I would say your 3000 stall converter is WAY to loose for your turbo setup but if you like it then that's all that matters.
LWATSON
Jul 30, 2008
2,587
55
Scotland Neck NC
I guess I missed that, so you have an old Precision your sending in for refresh and restall? Do you still drive this truck on the street?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Yes for time sake I'm sending out an old broken one tomorrow morning. That way I can work on pulling the trans here while it's being fixed and adjusted. Not street driven, I'll upload a video of my first attempt of spooling this thing last night
LWATSON
Jul 30, 2008
2,587
55
Scotland Neck NC
Just remembered, I know of two other trucks running the same converter I'm running, one with a billet S480 and the other a billet S483. They both spool at the track fine.
