LML What size hub centric wheel spacers?
twentythree
Apr 10, 2016
58
Hi guys, I need a little advice... I have a 2013 HD2500 Duramax 4x4 crew cab with a 4" Rancho lift running 285/65-20 BFG AT's on the stock 5pt. star forged wheels. I want to upgrade the tires to 35/12.50-20 BFG AT's the issue I have is the clearance between the inside of the tire sidewall and the suspension parts currently there's about a half inch and the new tires spec out at 1.5" wider. Any idea what the minimum width spacer I can get away with is? Anyone else running 35s on stock rims? Any recommendations on a particular spacer? Any help is appreciated.
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
Honestly you are infinitely better off getting offset wheels. But if you must wheeladapter.com
