i drove 200 miles straight at on 55mph... and only got 15 mpg!!!
ppe set on level 2
all else stock
ppe set on level 2
all else stock
jordan what tire pressure do you run on those 35's? i keep getting 17mpg going approx. 75mph with 4" lift & 35's. i think those m/t atz's rated up to 65psi i run 52
Like Tom said it could be alot. I'm pretty big on mileage so I make sure filters are all clean, tire pressure is good, that i've got as little crap
in the bed/cab as possible and just general stuff like making sure everything is greased well. Biggest thing is to switch to efilive too. I get 23 mpg hand calculated on a 4" lift with 35s.
I don't believe your mileage.
23 mpg? Is that from the DIC calc or your own math? I average 17 or so.....a non stock turbo makes you gain 5 mpg's?
Do all your regular maintenance stuff IE change oils, filters, etc and then if its still the same could be the fuel you use. 15 mpg seems kinda low.
I actually have gotten 23 one time and 26 another. the time I got 23 I was running stock 245's and runing 55 for 300 miles and when I got 26 I had a really strong tailwind for 150 miles. generally speaking I get around 19-21 running 65-70 for my so cal commute which is along the foothills so some up and down, 46 miles round trip.
