If the truck doesn't hit 5th in a 1/4 mile, you've got issues
:rofl:
pulling harder on motor
racing harder on drivetrain
thats what i think
Drag racing seems to be a bit harder on trannies, but pulling overall is much harder on the truck and the rest of the drive and powertrain.
If you think a 1.5 60' is at all easy on the drivetrain. On the track with good traction the power has no where to go - on dirt the lack of traction softens the abuse.
I didn't say drag racing was easy on the drivetrain, just not as hard on it as pulling. Lack of traction??? WTF! When is the last time you were on a asphalt drag strip and it had so much traction it stalled your motor?
Might want to try hooking to a sled with a track that has a good clay surface before you take this thread any further.
i think mike l is right about the low range everything has less stress with the gear reduction . think of a bycicle how hard do you have to push with your legs when your in low gear vs high gear . i will say drivetrain parts has to go to sled pulling , axels ect .
Put slicks on your truck and pull a sled on asphalt and I'd bet it'll stall your motor. ....
AFAIK it's the converter staying locked that kills it. Otherwise if you "lifted" when spooled up to 2500rpm, the engine would die, but it doesn't. Reason? Converter won't lock in first. But I could be wrong. Popping it in 1st always seemed to avoid killing the engine for me.
