What is GM book time for one head?
Vrabel
TOYAHOLIC
May 22, 2008
3,434
56
Hewitt, NJ
plus, how could you hone a cylinder? You dont no longer work there because you failed a pee test by chance, Eh?
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
no i moved, i know for a fact the heads didnt come off so im guessing he pulled the crank, it was in a lifted kodiak so there was enough room to sit between the oil pan and front axle and no way to pull the motor it was too high for any engine hoist.
ripmf666
15,123
14
47
Wentzville Mo
Head has to come off will come out with crank out bores there offset main block holes. Also you would screw the rings up even if there was room no way to get ring tool In.
duramaxxx06
Aug 11, 2009
177
jasper tn
ok, what about book time for a motorhome? its a c5500. I work at a normal Chevrolet dealership and they want us to do head gaskets on it. worst part is they are GOODWILLING the turd. so it will be warranty time. just curious how bad its gonna suck, especially since I have to do it outside....:(
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
Sorry but im calling BS on the "replaced the piston through the bottom without pulling the head" procedure.........
durallymax
Apr 26, 2008
2,756
Under The Hood
Are you sure it was a 6.6L duramax? They put other engines in them too. Regardless all of the inframes that are done install new pistons from the top.
2006 LBZ
Feb 8, 2011
195
Calgary, Ab.
I did a crank in vehicle with the heads on, bit of a task getting 8 rods to align properly all at once but other than that it wasnt too terrible
OregonDMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
OK to put all this trash talking to rest I went and asked him how hr did it and it turns out he pulled the head on a Saturday replaced the piston and put the head back on so when I went in on Monday All he had out was the oilpan and the melted piston which made it look like that's what he did. And it was a Kodiak with a huge custom lift so you could actually stand under the oil pan almost, so that made it look like it was extremely easy to do it dlfrom the bottom as the fender was about 10' high.
There everybody happy now y'all can Callate la boca :thumb:
