What is a "stock" Duramax ?
What mods you think SHOULD be allowed for a truck to still be considered "stock"
  • Total voters
    78
Noreaster
2,910
Cape Cod,MA
1. Turbo stock, no drop in wheels
2. CP3 pump any factory pump or regulator
3. Injectors probably the toughest thing out of the bunch, the list started out with stock injectors
4. Tires DOT, drag radials or any street tire
5. Manifolds & up-pipes :thumb:
6. Fans - electric fans :thumb:
7. Intercooler & piping I don't think an aftermarket intercooler is going to make a big difference
8. EGR delete / Y-bridge replacement :thumb:
9. Turbo inlet, mouth piece, elbow :thumb:
10. Down pipe :thumb:
Im going to add
engine - strengthening the shortblock should be allowed, the limits are being pushed & weak factory parts are going bend, crack, break etc.
stock cam & no port&polished heads
suspension - torsion bars & leaf springs, no coil overs or 4 links
truck - 2500hd or 3500 or for some off the wall reason van
13,751
821
IMOP its open season for anything but turbo and CP3 , makes it funner and give guys the fuel to get real creative and really push the limits.
I agree.
My thought as well. Stock turbo, stock cp3, too hard to control otherwise. Have 2 lists one fuel only and one for the spray/meth guys.
I think a fuel only and drug list would be a good idea.
616samuel
Apr 26, 2011
178
Rockford, Michigan
I don't have much of a say in this as i've never set foot on a drag strip... but as it is for truck pulls around me pretty much anything goes i guess if you can prove that you have a stock (none modified) turbo lol
To me my truck is not a "stock truck" i do have stock internals, turbo, injectors, cp3 & headers and up pipes... i've got the egr delete y-bridge, Banks intercooler, Fass, tranny & then the basic tuner exhaust intake etc... BUT there will always be people complaining about a "stock" form truck... even if we make a "stock Truck" just intake tuner exhaust, it'll never end!:roflmao:
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
easiest way i see it is any thing go's as long as you keep stock turbo/wheels/housings and a single pump. no drugs.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
How about an option for "None of the Above" ? :D
I think stock should be stock. No bolt-ons/mods to the engine at all. Built trans, lift pump and tuning only. A downpipe could be acceptable I guess. Suspension/tire mods are OK too.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Also lb7 injectors are bigger than LLY.....LB7s shouldnt be allowed:D
But LLY flow injectors flow the most out of the 4 first duramaxs..
If injectors are allowed why shouldn't modded cp3s? Really can't gain too much without using both anyways. Guys like me (and you'll start noticing more and more LBZ guys) have trouble holding rail pressure. I bought a big cp3 to try and cure that. I'm only looking for 26,000 WOT much nicer than 20,000, something some people have done weirdly on a stock pump before. I just bought it trying to make my truck where it should have been from the beginning, not to set records. Why buy a brand new lbz pump, when I could get this and have more room to grow? To make much more power with it alone you'd have to add more and more pressure to atomize much better, and iirc bodies will start cracking at 28,000 substaineds for long time. So really don't have too much gain on the other guy without having injectors to compliment it. JMO
Smokum
124
I don't have a dog in this fight, so I am not going to vote, but just a thought. Why doesn't someone just make a set of rules and go with it. I think there is one now, but I recall there being some gray areas and nobody is really "in charge". It needs to be rules where there are no ifs, ands, or buts about it. It would still be on your honor like it is now (that is how it is isn't it - there isn't an "official" inspection), and you wouldn't have this pissing contest all the time. You would have to modify the old list to fit the rules - if someone on the old list had mods that weren't allowed on the new list, they would be bumped off. It would be easiest to just start completely over, but I realize that alot of the trucks on the list are long gone from stock and will never be that way again, and that would not be fair, so just forget that I guess.
The biggest issue you would have doing that is who would get to make the rules? Obviously that would need to be voted on or determined some how.
Anyway, just a thought, but I think it would simplify things. Flame me if you wish.:thumb:
Drholliday
286
Gresham, OR
When I was stock I thought the "rules" where stock turbo, stock CP3 and stock injectors. Any one of those 3 things can get a truck up to 600 rwhp. doing 2 or all 3 can get you to that mark and over.
When I got on the list I was actually a built trans, lift pump and tuning. Everything under the hood was stock except for a shimmed FPRV. I was even on some bald 10 ply BFG AT's.
I really don't understand the drive to have the fastest stock truck to the point of dumping thousands into a truck to be the fastest "stock" guy out there. I was trying to go as fast as I could with as little money as I could. Once I wanted to go even faster I stopped trying to claim being stock and just started to add more and more parts to get faster.
I just thing the Turbo, CP3, and Injectors should be stock, or stock replacements, (LBZ/LMM CP3's/ turbos in LB7/LLY trucks or the other way around would be OK IMO)
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
Stock Turbo, Stock Injectors, a form of a stock CP3 (LB7 with LBZ reg ok)....and any normal bolt ons.
I think anything past that and you really make it unfair to the competition.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Stock = What I'm running.
Heavily modified = What the other guy is running.
This has been the law ever since the Model T.
In any case, IMO - Exh, Int, Tuning, Lift pump, regulator, Trans, EGR/Emissions defeats = BPU Basic Performance Upgrades. Injectors? That's a toughy. On an LB7, they are an internal engine part, but on LLY+ they are bolt on. So I'd say no.
