The turbo is a S363/68 in a non-wastegated T4 Housing. It will spool as fast and with some fuel maybe faster than the stock VNT turbos. They have been described as being electric. It does not matter what gear, speed, load, etc... this charger is alway right there ready to go. The two best features they offer are:
1. They are non-wastegated and are in OEM borg turbine housings, not molested S200 T3 Wastgated housings. This means the EGTS are in check like VNT guys have never seen before. A local LB7 fresh LBZ pump and 40% over injectors, dedicated DD and tow rig, will not crack 1200* on the tow tune and wont break 1400* on the Hot tune. We will have dyno numbers on this truck, and possibly cast to billet comparisons in the coming weeks.
2. The FPE S300 Line can be built with v-band front covers, that allow stock or OEM replacement aftermarket intakes to bolt up without modification. IE: LBZ mouth pieces and AFE Bladerunners. This setup eliminates the need for expensive spacers.
Bottom line is you can get an entry level, T4 pedestal based turbo with downpipe, install kit, and pedestal, that will support 600-625RWHP for under $2400.
Caleb
PS. We are also developing a variation of this turbo that will be a drop in replacement for the LB7 guys. :thumb: We should have some feed back from the test charger in the next few days.
