what fuel/air for low 12's?
gl4787
<-- just sits
Jan 27, 2009
274
WI
What kind of fuel and air do I need to run low 12's - high 11's? My boss has a fox body that may run around there and I just want to know what it takes to get there. Plan on having Exergy do my injectors, but don't know how big to go. Also, will any of the stock appearing units get me there? Are they worth it? Or would it be more cost effective to go with something different? Any help would be appreciated. -Garrett
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,496
479
Central OH
Better have some low mile rods :roflmao:
But an S366 should be enough air, stock injectors might do it I'm not sure. If you do nozzles, might as well do at least 40% over. Plan on shedding weight, and work on launching that pig.
The stock appearing IHI turbos will supply enough air, but cost wise it isn't worth it unless you need to pass tech while pulling.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
My fuel/air mods are in my signature. More air than I can use right now, but EGT's might his 1300 on a 11.9 pass so it stays cool
Tows like a champ too!
I would do a stock/475 twin setup and you will have plenty if air plus the spool up is still crazy fast!
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
161000 mile rods in my rig.
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
Since you have a lb7 don't waste time or money on nozzles until you need injectors. Its not worth the time and money for the small gain. Decent single and dual injections pumps will give you more than enough to pull that off. Alot easier and cheaper to do. IMHO I wouldn't go any smaller than 60% overs if you end up doing injectors.
DieselmafiaLLY
Keep Calm and Go Crazy
Apr 6, 2013
1,102
Ontario, Canada
Guy at the track this weekend ran a 11.76 on stock motor lb7, dual pumps, bigger sticks and double bat 366
Sent from my SAMSUNG-SGH-I537 using Tapatalk
