What does it take to run High RPM's
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I thought Jon (fingers) said something about the drivers/power supply in the FICM becoming a bottleneck, even with large injectors?
MarkBroviak
DMax Junkie
2,134
463
Danville Indiana
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
MarkBroviak
DMax Junkie
2,134
463
Danville Indiana
If you have the right parts combo and your motor is happy there then yes. There is a big difference in making power at high rpms and just spinning the rpms. Usually when limited on air they don't like to spin up that high loaded. At full power loaded your doing good to spin one up over 4800rpms, add air and away it goes. I wish it was just a simple yes or no answer!
bcdeutsch731
619
13
41
Illinois
Add triple turbo's a 9100 af cam, internally balance and Marks tuning and the thing will love to live over 5000 rpm. My truck is a blast to drive on the street!!!
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
How is the 9100 for daily driving? I'll never tow & I have a super loose converter. Triples with 250% injectors. I'm wanting to set my new build up for some daily driving & still be competitive in Super Street. Really need that high rpm to keep up with those guys. 6k+ lbs is hard to back half with.
MarkBroviak
DMax Junkie
2,134
463
Danville Indiana
The 9100AF would idea for what your looking for meshanic.
MAXX IT Out-Internally balancing is better for the rotating assembly because it keeps most of the weight as close to the centerline of the crank as possible. This helps the motors ability to accelerate quickly without wasting hp.
carpenca
Dec 17, 2010
168
Didn't Brayden say the lbz either fuels irractic, or stops at. 5200 or there abouts?
There was limiter that Brayden found while looking for the resolution for Jeff Deans Dragster (LBZ) which was cutting out. (5xxx ish RPM down the track?) In the process he spun the test stand over 7000 RPM, and the ECM continued to fire the injectors. Problem solved for Jeff!
https://www.facebook.com/video.php?v=10202430950871432&pnref=story
https://www.facebook.com/video.php?v=10202431178717128&pnref=story
Caleb
