What kind of slicks will you be running? Make sure to mess w/ the pressures and heat cycles in the burn out box, which also depends on how well the track is prepped. What is the altitude of the track you wil be running at?
1800'
you will be lucky to break a 14.0, trust me. I get low 13.x's with lots of spray.
The biggest slicks that work for us are the M&H Nostalgia's 12.0 - 16. They are 32 dia. Smallest rim would be a 10" rim.
My guess is 102mph. ET will 14.2 without slicks on a 2.5 60' time.
You will go quicker by adding as much weight as you can AFTER the rear axle. Some have actually poured lead shot into their hitches. $$$.
you might try a good all terrain tire, you would be suprised as to the difference they make.
14.9x's all day with H2's. I didn't build boost, just floored it from idle. No wheel spin for the most part, just chirps.
What did it run?
Well I am getting new wheels & tires and I want to go with the 285/65/18 terra grapplers, I herd they dont last long but they are soft so if they will help I dont care.
R/T doesn't change your et.
What did it run?
i have a 13.02 with a .454 reaction an a 2.45 60ft at 107mph. On 35's. My biggest killer was reaction time. Sleepin at the lights. 35's at 24psi.
